I have an Intergas HRE SB 30 running an unvented tank for DHW and a 16 Zone UFH system. I completed the wiring last night and it's all working fine.
However, the boiler has a DHW and CH mode which you can program for individual temperatures, but i can't see a way to call them individually? Right now i have all the boiler calls on the X2 connector Pin 1, which is the 230v LS. This always fires the boiler up in CH mode and the programmed CH temperature.
Ideally i would like to call CH and DHW individually, as the UFH is at around 45degrees, while DHW is at 65+.
Anyone know if this is possible?
Thanks!
Elliot
Thanks!
Elliot
