Ring and radial circuits?
28 Mar 2016
I have a new flat and am learning about the layout of its electrical circuits.
I've been able to trace 1 ring main from the CU through the loft and back again. There are 2 other MCBs marked "S/O 32A". Are these also likely to be ring circuits or could they be radial?
Just curious, no other reason!
Thanks, sorry yes ring final. Everything is 2.5mm so I assume it's most the other two all ring?
I have two other circuit from the CU marked "cooker 32A" and "water heater 20A". I can't see the wiring connections although there is one 2.5mm and one 4-6mm; is the cooker likely to be 2.5mm ring and the water heater 4-6mm radial?
Any idea what "S/O" would mean above the MCBs?
I assume these will be ring?
Almost certainly.
How many L conductors in each circuit breaker?
Is it unusual design?
Well - I guess since "flat" is the UK equivalent of the US "apartment", and some of theirs reach 10,000 square feet over multiple floors, I shouldn't assume that a "flat" is a smallish dwelling.
But 3 socket circuits for a flat feels "unusual".
