I have no problem referring to the Irish Republic which has 32 counties. That's not what we're discussing though.
26 counties since around 1923.
No. That is the Free State you are referring to - not the Irish Republic. Also it wasn't 1923.26 counties since around 1923.
You really are a space cadet.Interesting to hear the idea that parts of the UK are inside a foreign country.
In the same way that Dublin is part of Tasmania.
To get back to your original point, Irish wiring regs are similar to but have some substantially differences and this is one of them.
The normal setup in the Republic of Ireland is:
<Incoming ESB Mains>===<ESB Fuse>===<ESB Meter>===<ESB Isolation Switch & Bonding point to neutral since 1990s> (Demarkation point) === <Consumer Main Switch SP> === <Consumer Main Fuse or Master Breaker> ==== <Final Circuits>
Majority of installations are TN-C-S termed 'Neutralised Supply" in Ireland. Equipotential bonding is required for pipework. This is the preferred approach.
A small % of supplies use TT earthing, in which case there is a further RCD on the supply side at the meter.
TN-S is (AFAIK) not used in Ireland at all.
Other big difference is older Irish installations use German type Diazed/Neozed screw in cartridge fuses and not UK re-wirable or plug-in types - these were never used in Ireland.
Most installations also tend to use radials (usually 20A) rather than rings and RCDs were adopted for socket circuits much earlier than the UK.
Normal sockets are BS1363 [translated as IS401 sockets and IS411 plugs - but identical spec to BS1363]
'Schuko' CEE 7 was used in the past in Ireland and is still permitted and defined in IS 180 : 1997
However, you would struggle to find any remaining installations. It was common place until the late 60s. You'll only ever really encounter it as a convenience socket for tourists in some hotel rooms.
(It cannot be used on rings without being connected via a fused spur)
BS 546 - only 5amp version is permitted for switch-controlled lighting and is also defined in IS 180.
I wasn’t in GMT+1 timezone when I was posting.
Basically just beware of two things in Ireland:
Wiring rules are a bit different to the UK and make sure you’re aware of how the two systems do things as they’re both amongst the safest in the world when wired to code
Ireland's had mandatory RCDs on sockets since 1980. Originally they were quite expensive devices, so they tended to only want to use one on an installation....
... On a TN-C-S supply single poll is absolutely fine.
On TT earthing double-pole is necessary.
