Switch wire. 2 of 3 are live!
If you really have tried every permutation and nothing blew up then it seems like there is no live at all to that rose. There are several permutations that would cause a short-circuit. This should be trivial to check with the right equipment. If two of the black wires really were live then connecting either of them to the other black wire would be bad. Time to start again and follow the instructions more carefully.
No. 2, as No. 1, 3 red wires and the switched live have juice. The two neutrals are together and the three earth as well. Beats me that it doesn't work.
No. 2, as No. 1, 3 red wires and the switched live have juice. Beats me that it doesn't work.
If so and now properly tested, there are still all sorts of reasons why no light. The obvious one being that there is a loose, broken, or disconnected wire in the fitting (or possibly elsewhere). Or the light bulb has blown :) Test continuity on those wires.
There is one obvious difference between the two fittings. It shouldn't prevent operation but should probably be corrected anyway.
The bulb is OK. The connections on the rose are sound but, as you say, the problem could be elsewhere. It looks as if I will have to succumb and call an electrician. Thanks for coming in.
Have you thrown away your neon screwdriver yet?
Let us know when you've done that and we'll tell you what to do next.
Thanks for the advice. Thrown one that didn't work but kept the one that does. The repair is now beyond my capability in electrics but I've learnt quite a lot posting here. Thank you.
If you are so convinced that you have tried "everything in the book", and will not try Plan A, then all that is left is Plan B - get an electrician.
Nobody here can help you, and a dwindling number will want to if you aren't prepared to follow advice.
Throw that out too. They are unreliable and can be dangerous and of no practical use because of that, and your unwillingness to use the right tools, and to put some effort into understanding how things work, mean that you don't need it anyway, as you really shouldn't be doing electrical work.
But not, I am almost certain, beyond the capability you could acquire had you the right attitude.
Your Plan A suggests that I should become a professional electrician before tackling the problem and at my age I am not prepared to do that. Thanks anyway. I've learnt a few things I didn't know so I am improving!
Stop throwing punches!
No - just learn how something pretty simple works IF you want to fiddle with it. It's a domestic lighting circuit, not the control system for a nuclear reactor.
None of them work reliably enough to be useful
I doubt that. It should be quite easy to fix once you take the right approach.
Idealy you'd buy or borrow a multimeter. Failing that, you could improvise a continuity tester by dismantling a torch or something else with batteries in it. If you can't do that then it gets more complicated, but it's still possible if you have patience.
