Tahar Gamboura3 months ago (edited)
l'appareil ne déclenche pas parce que un plombier a touche la vice cancernant pression a gaz s'il vous plais dite moi que pourai- je faire Mercie d'avance
Corpse Reviver3 months ago
Hello Sir, I'm using same boiler as yours. Can you please tell me what does 44 A means with flasing red? And No hot water?
Jane Fung9 months ago
the boiler won't even give me hot water anymore , just flashes . useless
Ismail Daci1 year ago
this boiler is rubbish
agreed .
Ismail Daci9 months ago
Yes it is
Sefgrt1 year ago
What does FH mean. My boiler has TS flashing. I have re-pressurised it, but it is will not move off TS. When I press and hold reset, it displays FH. Any ideas?
Oh my God! That at 30C not 35C hence 18.6 litres per min.
The brochure states 16 litres/min:
http://www.ferroli.co.uk/brochures/Ferroli-Modena-Brochure.pdf
Compare that to the very poor Intergas DHW performance.
Our one boiler wonder, you got spanked!
No different to any other it seems:Great boiler and easy for the end user to set up.
Well spanked indeedy. What Intergas models go up 16 litres a minute?Spanked? Methinks not.![]()
Ever used an Intergas? BTW, a thermostat/timer of your choice can be used.And yet there are no complaints to be found on the intergas clips![]()
When some convert an open CH system to a pressured one, sometimes the radiators bulge out. The corrosion made its mark.I have a 5 metre 15mm copper pipe feeding the mains in my house. Plenty of flow and pressure although reading one of the above posts, it reminded me that I did have to replace the float valve in the downstairs WC (too much pressure) and the cartridge in the hot side of the kitchen mixer tap (dripping when converted to unvented cylinder). Cold side of tap fine after the switch from gravity to mains pressure.
Our one boiler wonder is screen shotting the wrong boiler model. Those comments are not on the Modena 32C, 38C. Hilarious. Spanked again!
You can do but you will be spanked.
Look at the Ferroli 38C manual. Download it. Clearly states 16.4. The Modena only has 4 moving parts. Quality components inside.
