- Joined
- 14 Mar 2017
- Messages
- 7
- Reaction score
- 0
- Country
So...
I need some advice on my rights, what I should, how calm I should be. I have a lot of pictures and things in writing but no contract.
We've employed a building firm to renovate our flat kitchen. (As yet we have paid nothing but were given a quote of £2.5k and around 8 days).
The contractor advised us to use Howden's for the units using his trade discount. The Howden's planner came round and CC'd the contractor in to the proposed plans.
Appliances booked, delivery dates sorted! Contractor agrees start date based on these.
Work begins, they gut out the old kitchen, and then seem to be heading in an unconventional direction:
I'm
- They started with the floor tiling.
- They look at the "plans"... Oh we can't use this and that unit because of the stop-tap. We can't use the radiator you bought or wall mount it because it's a load-bearing wall and the pipes run underneath it.
- They start building the units and put everything in the wrong place, plus they're missing bits. So I call the kitchen planner and he brings a missing unit and the actual plans with dimensions. We are now four days in and this is the first time they've looked at the dimensions/measurements.
- Everything is moved around but in the process some units are damaged and they are still not in the correct position.
- The contractors said it was impossible to move the fuse switches but now they've offered to put them in a cupboard, however this is done really badly and to cover a huge gouge they've made.
- They said a sealed mitred joint on laminate was impossible until I showed him one after they had fitted an ugly, cheap metal strip joint.
- They've scratched the new sink putting it in.
- Originally they fitted the units to be 10cms higher than a standard kitchen and blamed Howden's. So they had to take them all out and cut them down.
- They've miscalculated the measurement of the washing machine space so that the skirting board won't fit next to it. It's meant to be 631 and they've given 600. They're solution is to screw a piece of skirting board on so that it can be removed when maintenance is needed. I pointed this out and he laughed at me repeating "How can I make the gap bigger, you show me, how, how can I, show me"
- With all the delays I asked an approximate completion and was told they were over-time because of the appliance and kitchen delivery dates.
- Plastering was done after everything else.
- A lot of units have been cut unevenly.
- I asked for the laminate top to be finished with a laminate end but he's insisting on a metal cap that looks cheap and attracts grime.
- He told me that 8mm black or grey tile trim doesn't exist and that he has to use stainless steel.
I'm
