HI all,
I am currently in the process of having a loft conversion done, of which I am planning to upgrade/change the heating and hot water system as the house will be a 5bedroom with 3 toilets once complete.
I currently have a condensor boiler which is 24kw, which has the usual cold water and hot water vented setup. As part of this I'd like to upgrade to an unvented system but I have a few questions about this.
1) Direct or indirect? My builder recons direct unvented costs less to heat up water than indirect, I would've thought using electricty would be more expensive? He recommended running a direct unvented for the hot water, and changing to a combi for the heating. -Could someone shed some light on if they would recommend this please.
2) If I were to keep my existing boiler, could I just add the unvented and remove the cold water storage in the loft and the vented hot water cylinder? Or will I have to keep the cold header tank?
3) I have a feeling a 24kw boiler will be too small to heat around 18 radiators (once finished)- Should I change the boiler at this point too? If so what boiler/setup would you recommend
I will certainly be using a G3 installer for this, so nothing to worry about there. Just wanted to get some background info before consulting plumbers.
I have also checked, there is a 22mm mains water pipe coming into the house.
Many thanks!
Many thanks!
