*****winston1 said:As is your atrocious spelling
What have little furry animals to do with transformers?
Despite their common name, these animals are not in the pig family Suidae, nor do they come from Guinea.
And yet he thinks that he can ignore the fact that he has no objection to "electronic cigarette", even though they aren't "cigarettes", and he insults everyone here by expecting them to believe that it's "off topic" to point that out.there is NO SUCH THING as an electronic transformer. It is a name coined by ignorant manufacturers and propagated by ignorant electricians who don't understand what a transformer is.
As far as suppliers are concerned, and therefore as far as DIY users are concerned. "Electronic Transformers" is in common use and easily understood, whether you like it or not.
We've had enough nonsense over this. Therefore the use of the term will be allowed in this forum, and those declaring its use as incorrect, outside of this thread, will be deemed Unhelpful. Further such posts by you may be deleted without comment.
Mod
SorryWell done, Rocky.
So - thanks to Rocky's intervention Winston escapes having to either again claim it was off topic, or to be seen, without doubt, to be ignoring the question.
But yes - that of course was it.
He thinks that he can ignore the fact that he has no objection to "electronic book", even though they aren't "books", and he insults everyone here by expecting them to believe that it's "off topic" to point that out.
We do not know whether he accepts that guinea pigs exist even though they are not from Guinea nor are they pigs, but I think it's safe to assume that he does believe that they exist.
I believe that even in this thread, saying "there is no such thing as an electronic transformer" should be treated as what it is - a lie, and the person saying it "umpteen times" should be treated as what he is - a serial liar.
Are they?Been out all day today. Little furry animals, guinea pigs, are definitely OFF TOPIC on a thread devoted to transformers and SMPS as I stated earlier.
Stop lying.Also as I stated earlier there is NO SUCH THING as an electronic transformer.
Stop lying.
FWIW, when you did that you did it on the "basis" that I had said something which I had not, and which you clearly fabricated - within the space of a few posts you decided to claim I'd written something which I patently had not, and you then decided that as what you had invented would have been untrue, I must have lied.When I accused you of lying you went off and sulked for a couple of months, and everyone kept asking what had happened to you.
I didn't say it because I expected you to do that (as much as we would all love it).Don't expect me to act so childishly.
You really did write that.there is NO SUCH THING as an electronic transformer.
How can that possibly be the case, Winston?By the way little furry animals are off topic, but if it pleases you of course they exist.
It has everything to do with your so-called "justification" for telling lies.But it had nothing to do with transformers or SMPS.
For pity's sake.
People are ignorant of the way LED lighting operates and this is because the marketing industry is also ignorant and uses the wrong terminalogy. One major supplier is selling 12 volt fixed voltage "electronic transformers" as LED drivers. LED Drivers control current to suit the LED elements. What they are selling is a voltage source or power supply.
The devices labeled as "electronic transformers" are power supplies that may be designed to provide a constant voltage. ( power supply ) or a constant current ( LED driver )
99% of these will have a transformer inside them along with a variable number of other components. These components create a high frequency chopped supply to the primary of the transformer which allows for the transformer to be a very small item.
So we have two basic types of "electronic transformer" but both are labelled as "electronic transformer". The first type supplies a constant voltage and the secnd type supplies a constant current. Some of the constant current type are known as LED drivers as that is what they are designed for. to drive a constant current through an LED element. Most LED lamps have this current driver ( or something similar ) fitted inside the lamp. These lamps require a constant voltage supply, they do not need and probably will not work if supplied with a constant current from an "electronic transformer" has been sold as an LED driver. Using an LED driver to force a current through the lamps with internal LED driver may damage the lamps and / or the LED driver usedas its power source.
how can guinea pigs exist when they are not from Guinea and they are not pigs, and their name was coined and propagated by ignorant people who didn't understand where they were from or what they were?
So you would agree the name "electronic transformer" was coined by ignorant manufacturers and propagated by ignorant electricians
Not ignorant electrians but electricians easily led by the marketing people who can no longer be trusted to tell the truth ( or the whole truth ) about new technology if to do so would compromise sales.
