The TLC one said for LEDs. I saw the one in Screwfix, but it is marginal. I thought what if three 8W LEDS are fitted in the future. Then trouble. The idea is to fit a transformer that will deal with three of the max wattage of LEDs on the market.
This is getting tedious.
FOR THE ELEVENTH TIME you need a proper power supply designed for LEDS.
The OP requires a power supply designed to supply a voltage the same as the voltage rating of the lamp. IT DOES NOT HAVE TO BE DESIGNED SPECIFICALLY FOR LEDS. The driver inside the lamp adapts the power to suit the LED elements.
The only supplies readily available are 12v DC supplies sold as LED drivers
OK, where there is disagreement:
Was I right?
- Bernard says that as long as it is constant voltage or 12v ac/dc it will work.
- Winston says it needs to be 12v ac/dc but is the frequency that matters and it has to be 50/60hz, no other hz, or no hz at all as in pure DC.
This looks like it would do. I saw nothing at Screwfix that looked suitable.
The manufacturers quote frequency for a reason. Go, think some more.
but unlikely to be found in a bridge rectifier intended for 50/60 Hz AC.
At high frequency the parasitic capacitance of the diodes comes into the equation. The capacitance is a bi-directional low impedance path shorting out the diode. Significant current flows from AC1 to AC2 through the parasitic capacitors even when the + and - outputs are not connected. This current heats the internals of the bridge rectifier.
If you have read the thread you will find I have a hell of clue.That quote confirms you aint got much of a clue,get a qualified person in.
6 pages of advice,84 posts and your still here asking questions.i rest my case.If you have read the thread you will find I have a hell of clue
If you followed the thread, which I am sure you have not, it is a debate which I am following.6 pages of advice,84 posts and your still here asking questions.i rest my case.
Did you not see my explanation a couple of pages back
https://www.tlc-direct.co.uk/Produc...1LBE3DZCUY7C_fscV51XH7Hh0uEM6aA8aAvNvEALw_wcB
The Varilight one is fine. They're available at B&Q if you want to try one before buying multiple, but they give an output suitable for just about every 12V halogen replacement LED lamp.
http://www.diy.com/departments/varilight-transformer-115v-50w/933229_BQ.prd
