Any pictures to show us of your Earth Wife?
So assuming you use the correct cable 5 amp will be OK.
For appliances up to 700w you use a 3A fuse and for appliances over 700w you use a 13A fuse.
Winston, please accept that there are items of equipment where the manufacturer does include the fuse in the plug as part of the over all safety arrangments to be in place when the item is being used. For example limiting the amount of energy created in the short circuit arcing when a flexible cable fails close to the hand of the person using the appliance. ( Hair driers, hair straighteners, both have suffered "explosions" where the cable enters the handle of the appliance )
By that logic, UK plug fuses below 13A provide no benefit with 13A cables, and should never be used with them.So what does that manufacturer do when he sells the same items in Europe? He certainly does not use a special European plug with a fuse.
