I have a small extension measuring 2.3m by 1.35m which runs along the rear wall of my bungalow. It has a flat, felted roof which is in a poor state of repair.
The bungalow roof slopes down toward this extension and guttering runs along, above the flat roof, to capture rain water from the bungalow roof. The bungalow roof slope is around 90% which is covered in clay tiles.
I would like to replace the flat roof with a 22.5% pitch roof using reclaimed clay tiles. I would like to feather this into the original bungalow roof.
I believe I should raise the wall plate of the extension to the same height as the bungalow roof wall plate and run a ledger along the bungalow roof rafters. The new extension roof rafters would the sit on the installed ledger and extension wall plate.
Thank you
Chris
- Is this the correct method?
- Please advise what size timbers (ledger, rafter, wall plate)
- Please advise what are the correct jointing techniques I should use along the ledger.
Thank you
Chris
