Curved brick arches above windows in new extension
That's why all the ones I've seen on site use steel cavity trays and support systems or lintols. A lot of them come in ready made as part of the lintol.
That's more a commercial decision based on time and ease, and the skill of the workforce.
If you really want a traditional brick arch just crack on and get it built, the building inspector is being a muppet.
However there is one flaw in your initial suggestion, do not put in a lintel above the arch, the weight of the wall above the arch makes the arch stronger, it needs to be in compression (or is it tension, I can never remember). You would only put in a spreader or relieving beam if there was a large point load coming down onto the arch.
Oh and don't forget the cavity tray, always tricky with an arch in a cavity wall, you'll probably have to put that in the course above the arch.
It's better to buy a purpose made one nowadays. They make them along the road from me in Yeovil.
Weathering of the arch in a cavity wall used to be more of a problem in the past.
I saw one of the Council BCO's today and asked about this issue. He said that they would require some details if the arch was unsupported by a lintel.
An arch works perfectly well if constructed properly. If not it can fail. I can understand them wanting to know what a novice working on a building notice was going to use to span his patio doors or similar for example.
I ordered 4 curved steel lintels from IG in the end, quite expensive at £500 but they will do what i want and keep BCO happy. I also do not need a cavity tray over the lintels as i have sufficent eaves overhang of 300mm.
Thanks for the suggestions.
Complete waste of money.
And if you are saying that you have eaves just above the arch then I would need to find another adjective that means worse than "complete".
Maybe yes, but it keeps BCO happy, gives me (Novice) an easier time building the arch. If i was to buy standard flat lintels and arch former's it still comes in at just over £300.
What would you do?
