- Joined
- 9 May 2017
- Messages
- 4
- Reaction score
- 0
- Country
Hi All,
Was hoping someone would be able to help. Have a flat with an entrance leading to a set of stairs with a light at the top.
At the bottom of the stairs is this switch with the following wiring.
The at the top of the stairs is the following switch with the following wiring.
The problem is that only one switch can be used at a time. If the bottom switch is used to turn the light on, the bottom switch must be used to turn the light off, the top switch will not work.
If the top switch is used to turn the light on, the top switch must be used to turn the light off, the bottom switch will not work.
Obviously this means going back up/down the stairs which is becoming a pain.
Both switches are marked as 2-Way.
Any suggestions would be appreciated.
