It's not as if you weren't told that that would happen....
I'd missed this first time around.You need to change the position of two links between four terminals.
This can not be done with a simple switch. You need to use two interlocked contactors, and some complicated wiring to do this.
Said connections having originally been made by a lazy git who just couldn't be bothered to do it properly.The bare copper will be the remains from where L&N connections were cut off when disconnecting the motor.
Wasn't able to be switched with the contactor released therefore not used to power the motor on or off, this is a factor I would have checked at the time, it was a small fan, say 1K tops.What's the AC3 rating of a standard intermediate switch?![]()
I believe you have correctly worked that out and no it doesn't make sense.What do we think the TWO devices labelled K are ?
I've tried sketching out what the connections actually work out to in terms of windings, and they just don't make sense to me !
It makes sense for the device connected between V1 and Cst to be a centrifugal switch - just connects additional capacitor during starting for better starting torque.
But what about that switch on the left ?
In the CW setting, it shorts out winding V, leaving winding U across the mains and winding Z in series with the cap(s) across the mains. Once open, then it's winding V in series with the paralleled U and Z windings.
In the CCW setting, winding V is permanently across the mains, windings U and Z are still in parallel (Z in series with the cap(s), but connections reversed) and only supplied with power while K is closed.
Perhaps someone else could try sketching it out, it's just making my head hurt.
This is not a kosher arrangement, even though the professional looking diagrams would indicate otherwise.
So I'm not alone in thinking there's something very odd about the wiring for this motor.I believe you have correctly worked that out and no it doesn't make sense.
That's one of the effects of having a start cap - the increase in starting torque also means a bigger jerk on starting.... I do recall it ran very smoothly and quietly but started with a big jerk just as OP mentions.
