Hello all.
Had a bit of an issue with my current oven and it needs replacing. It's a single built in, housed in a standard 60cm cabinet from what I can tell.
Is there any way to get a double built under in there? They measure about 70 cm high.
It has a void underneath with a panel on top as shown in the pic. If I removed the panel and shelf holding the current oven the space would be increased to 68.5cm, which I assume (hope) is enough for the internals of a 70 cm double to get in to.
Is this feasible, or is there some other way to fit a double under, I read some might have legs that sit on the ground and the oven hangs over the plinth.
Thanks for any help.
