Isolation valve fitted wrong way around
14 Jun 2006
Hello,
My monobloc basin tap has broken and needs to be replaced.
I turned off the 2 isolation valves but notice one of them has the arrow pointing away from the tap, ie the wrong way around.
The water has stopped flowing out of the tap but I read that sometimes a small ball bearing may fly out of the valve once I disconnect the tap side flexi connector - is this likely to happen ?
Not sure whether its on hot or cold feed, my system is gravity fed with cold water tank supplying bathroom cold if that matters.
Thanks!
you don't need to worry about pieces flying out ,you do not have very much pressure in a gravity fed system .
PS ,I would drain the pipework and fit a new valve the correct way up ,couple of quid to buy and easy to fit. you must of course turn water off and drain to do that.
OK thanks, that's reassured me, would hate to disconnect it then find it fails and water goes everywhere!
With regards to draining, to isolate hot feed I guess I just close the gate valve feeding cold water into the bottom of the hot water cylinder ?
yes but if on cold you need to find the valve , if you have one, that isolates the feed from loft tank to cold taps. if you do not have one ,you isolate feed to tank and drain ,or use a bung.
your welcome. by the way when choosing new tap ensure its suitable for low pressure ,and it comes with flexi hose tap tails ,not copper as some do.
Copper would be preferable no?
much easier for a diy'er to connect monobloc with flexi's. the copper tails offer limited flexibility and invariably do not reach /align with supply pipework. although one end of them is 15mm the other end is step reduced to around 6/7 mm ( I.D ) to fit into mono base ,so the flow difference is minimal between them and a flexible hose.
Starfire ,think that tap is only suitable for high pressure plumbing system. regards terry.
Change the ball valves for full bore, you should see an improvement in flow if you are using a gravity system.
What ball valves do you mean?
Managed to fit the new tap OK so happy about that
