- Joined
- 27 Jan 2008
- Messages
- 28,804
- Reaction score
- 3,519
- Location
- Country
The re-wire I had done was cheap, I knew this and it suited me, the garage was powered from a switched FCU in the bedroom with an overhead cable, in the garage there was just one double socket, and a switched FCU as a light switch with two simple bulbs. I was good enough when fitted, but then realised I really needed a double socket either end of garage and also two way switching of the lights, from main door and side door.
Because the light switch was a FCU to turn into two way I replaced it with a grid fuse holder and two way switch, after changing I then went to swap the fuses, I had expected to find a 3A for the lights, as there would be little point in a fuse same size as the one in bedroom.
However found fitted with 13A, not really a problem, and likely it breaks no rules, however I now wonder what else? Had I not swapped it to two way switching I would have not opened the fuse holder, simply no need to look. It is 9.5 years before it needs an EICR and although one may look at a MCB size, how often does one actually draw a fuse to see what size it is.
