Zip, then.Showing that the RWR on GD are exactly the same the world over - if all else fails, lie to those who will listen.
I never said I agree with it. I am for people contributing to their care though, I think you'd see the waiting times half if people had to fork out a few quid for visiting a GP, for example, £20 a time? Perhaps it would force people to take more responsibility for their health as well rather than put all their faith in another person. I think there are those that abuse their health deliberately because they know the NHS will sort it. Needs to stop.
It's not all about money, it's about the way the NHS is run. Not everything is solved from throwing money at a problem. If this were the case the NHS problem would have been solved under Labour who have no other ideas than to borrow more money to fill massive holes in funding.
How is this tested and how can this system can be safeguarded against abuse and misuse as it often is? The answer is to disallow it entirely. The migrant is here to be used, if they which to stay they should be forced to jump through hoops, like thr system in Russia where you have to live in rented accomodation for a minimum term before you can be considered for buying your own place, even then there are more barriers. It shows commitment from the migrant if they really want to be there enough, they will work hard to stay. Review the Russian points system, it works and discourages freeloading scum.
One of the problems is that it is oversubscribed and mass immigration is one of the reasons it's failing, not the only one.
Never said it was.
Similar to all travelling EU nationals.
Have you researched it or are you just trying to appease the RWR by resorting to the usual "I'll type something I know probably is not true then hope no one proves me wrong" approach.
In what terms?Zip, then.
In what terms?
What do you think YOU achieve when you post on here? As long as there are bull s hitters there will always be those to set the record straight.
Do you think exposing liars is non-worthwhile endeavour?
In what terms?
I only encounter RWR's on this forum. This seems to be their platform for lies, stupidity and fantasy.Do you save this forum alone with your parity or are you saving many others too?
Most? You mean there are some that are more driven or equally as driven?most posters on DIYNOT aren't quite as driven as you.
Fine and dandy thanks.so how is this noble cause / mission going then noseall
not to well imho![]()
It makes a difference to them. Never forget that.Well done for dealing with all 10 or 15 of them. Talk about making a difference. You've got it nailed.
It makes a difference to them. Never forget that.![]()
No thanks.You need to get on more forums. You're missing major opportunities.
Bulls hit, lies and fantasy is everything to the RWR, they depend upon it.does it ? How so ?
