Hi all,
I need some advice if possible, extension is starting on 2nd Aug, contractor selected (recommended by the draftsman who did original plans), planning permission obtained but I have no building regulation drawings or pre approval for building regs, is it possible to build without them on a notification basis and have it inspected as the works progress? Is this a bad idea?
This is the first build / extension project I have been through and i'm feeling really unprepared. Would really like some advice or tips from builders or people who have been through similar projects.
The job is to remove an existing conservatory and then replace with a brick built extension with roof lantern and patio doors. I have attached the quotation to give you an idea of the detail the builders have gone into which seems ok to me but i don't really know what i'm looking for.
The builders are a large firm with about 60 employees and they say this is a small job for them which will take 6-8 weeks. How do i make sure it doesn't run over or they don't leave my job and go and work on something else? I'm moving out whilst work being undertaken so could not have it delayed significantly.
I've been told there will be a contract and stage payments which i guess is important. I'm just a bit out of my depth now the date is drawing closer and i would like to be prepared or at least know what to look out for or get in writing before the work commences.
Link to quotation document - https://www.diynot.com/diy/media/extension-quotation.100019/
Thanks in advance for any advice!
Cheers
Cheers
