Euramo Gold was a 5M head, if memory serves. Tony is talking rubbish, a replacement doesn't not need to be a ERP circulation pump.Hello everyone.
What's the most compatible replacement for the that pump?
Grundfos 15-50 or 60 will be ok?
Hold on to your old boiler as long as you can matey. It may be OK for 30 years.My heating system is so old (still with hot water tank)need to be changed soon but at the moment it is Mexico slimline rs445 or cf440 (I'm not sure which one but maybe these are similar) with 5 radiators.
These are good;
https://www.ebay.co.uk/itm/291942734155
About 26 so far, we flash test them & not one has failed during field trials.Don't install Katsu!Their tools are bad enough copies. Technically not for the UK market and Katsu are unable to provide a certificate of conformity.
If you actually are a pro, please tell me you aren't installing these?
There's big moves in the trade to ban ERP circulation pumps, when we tell the chinless wonders in Brussels where to stick their Directives.
And you can stick your clipboard where the Sun don't shine!!
Are you seriously comparing me to that??!!! Of course I'll report this as a disgraceful insult & abuse Tony. It's ridicules, the worst a faulty circulation pump can do is trip a breaker or leak, hardly a comparison FFS!!I only said that you "should" fit an energy saving pump. All the boiler manufacturers are using them now.
I have never seen one of those Chinese pumps and would certainly not want to use one unless it was the last pump in the world. I like to use good quality products for my customers.
Not sure what Puller sees as the advantage of using them. Unless its for social housing and just to use the worst and cheapest. Look where that got Kensington and Chelsea Council!
Why??Well the OP should just fit the Grundfos either way. Should be able to obtain for £60 to £80.
