Seems to be the way new builds are done these days.Why on earth is there a switched FCU for the fridge/freezer? Surely it has a fused plug on it.
You can push the fridge closer to the wall if the outlet is behind?Why on earth is there a switched FCU for the fridge/freezer? Surely it has a fused plug on it.
I put our fridge socket behind the adjacent cupboard for that reason though, then you can deal with the plug without having to move anything.
Why not?Why on earth is there a switched FCU for the fridge/freezer? Surely it has a fused plug on it.
Maybe it's an integrated fridge, with a flex outlet behind.
Maybe the switched fused spur supplies several sockets.
Nothing wrong with using a switched fused spur anyway.
It does in the febrile minds of some here.Pointless doesn't necessarily mean wrong or unacceptable.
True, but it's the 'obvious' thing to do (if one wants an above-counter switch) - so, unless one is for some reason 'forced' (or feels constrained) to comply with every word of BS7671, it seems the sensible thing to do.If you did away with the one in the switch and used a 20A DP instead of a spur, you open a can of worms by connecting an accessory not to BS1363 to a ring final....
... if I need to defrost the freezer, or I have pressed go on the washing machine without putting the tablet in and need to realse the door, I don't want to have to pull the bloody things forward in order to switch them off. Yes you end up with two 13A fuses in series, but does it matter....
If you did away with the 13A plug, you'd cause problems if you have paid currys to deliver and install a new appliance, they'd drop it in the middle of teh floor and clear off as it wasn't what they were expecting, the plug also allows you to isolate teh machine in a was thats obvious when repairing it.
Indeed it is. However, as I've just written, for those who wish (or are forced to) worry about such things, it is, strictly speaking, not compliant with BS7671. Both of us are at risk of being criticised for 'encouraging' people to disregard regulations!There is no problem with a 20 amp switch on a ring final. In fact it is quite common.
Really?it is, strictly speaking, not compliant with BS7671
I don't believe it is (strictly compliant), unless someone can prove me wrong...Really?
Yes. You need to revisit the precise wording, and consider a)what it permits, and b)what it proscribes.Do you disagree?
