If you mean fitting plastic trunking on a wall and the part with the tiles sticks out further than the rest, then there are a few options
a. Install larger trunking that required and trim the back off where it passes over the tiles
b. pack out the section of wall without tiles to the same level as the tiles using Foamex board or similar.
c. install deeper trunking on the wall and shallower over the tiles. Only works if the difference between the two is the same as the tile/wall difference.
What do you mean, you "found" it?Hi,I found an old post asking how best to do this but apparently it's too old to add to (2008).
Hi, any ideas how best to lay trunking down a wall where the bottom half of the wall is tiled. i.e. hoew to negotiate the lip where the tiles start?
I have thought of fixing a slim piece of timber the same width as the trunking onto the plaster and then laying the trunking on top thereby removing the lip. However, before I start are there any other ideas/products out there?
The problem remains.
Oh.I honestly don't remember posting this 9 years ago!![]()
