- Joined
- 11 Jan 2004
- Messages
- 46,558
- Reaction score
- 3,841
- Country
What happened here?Deleted.
I didn't say it was not allowed. I said there was never, ever, a reason to do it.Here is the list of devices considered suitable for use as fixed lighting points:
- A ceiling rose to BS 67
- A luminaire supporting coupler to BS 6972 or BS 7001
- A batten lampholder or a pendant set to BS EN 60598
- A luminaire to BS EN 60598
- A suitable socket-outlet to BS 1363-2, BS 546 or BS EN 60309-2
- A plug-in lighting distribution unit to BS 5733
- A connection unit to BS 1363-4
- Appropriate terminals enclosed in a box complying with the relevant part of BS EN 60670 series or BS 4662
- A device for connecting a luminaire (DCL) outlet according to BS IEC 61995-1
- An installation coupler BS EN 61535.
I probably have higher qualifications than you. AMIET for your info.
Whooaahh there!There is no objection to using a 2 or 5 amp BS 546 socket however.
AMIET, is not an indication of a qualification, experience or electrical knowledge. From their website:
"To join the IET as an Associate, you do not need to hold an engineering qualification. You may be working in a related field, have a passion for engineering and technology or you may be a retired member. Engineering and technology affects our daily lives which is why the IET welcomes the support, contribution and involvement of a wide range of people.
If you have graduated within the last five years you may be eligible for our IET Advantage membership programme - for early career engineers, for which there is a separate membership application process.
By joining as an Associate, you can access a range of membership advantages for an annual membership fee.
An Associate may also transfer or upgrade their membership to the Member category once they have acquired the sufficient skills or experience."
So you have paid for membership of a club! I pay for membership of my local bowls club, can't stand bowls but they do a good pint. Also, an MIET, once told me that that the conversion method of 2 way switching didn't work, in front of half a dozen or so bemused experienced electrical design engineers.
Unfortunately the MIET seem determined to make themselves booksellers but otherwise irrelevant.
They have clearly changed the rules then. I certainly had to pass very stiff exams HND and above before I became AMIEE as it was then.
Winston, do you think that if you keep on "clarifying" that (when not one person has claimed you said it was not allowed), then somehow we will all lose sight of the fact that what you did say wasI didn't say it was not allowed. I said there was never, ever, a reason to do it.
What we don't need to do is encourage it with unsuitable sockets on a circuit primarily designed for lighting.
So how much did you pay?
and that what I have been doing is showing you the list of accessories which BS 7671 says are suitable ?
But the most important part was the technical qualification not the cost.
Eh?The regs are not BS 7671.
I've seen it once in my career, and only because the B6 regularly tripped on turning the hood on. Carp design.Simplest and widest used method of supply to a cooker hood.
Or FCU.My loft has no socket circuits in it, but it does have a lighting circuit. How do you think I should power my aerial amplifier?
(Clue: a suitably labelled 13A socket-outlet)
Or FCU.
