Line Taps
24 Nov 2004
Trying to source a product for joining up scrap lengths of 10mm2 conductor.
Like the look of Hellerman Tyton Sigma range of linetaps but cant find dimensional drawings for them.
the catalogue page describes the S10 product as "10mm2 cross section cable"
the catalogue also says that "all sizes can be joined together"....
Does this mean that 2 lengths of 10mm2 conductor will comfortably fit into an S10 tap?
or
should I be joining 2 x S10 taps together and clamping one conductor in each (for a join)
help appreciated
I presume the connection is the width of 10mm² cable.
Just for convenience or neatness; not electrically.
Yes.
or should I be joining 2 x S10 taps together and clamping one conductor in each (for a join)
No.
The point of a "line" tap - what the "line" refers to - is that they are used for joining an additional conductor to an unbroken first conductor.
That is, you tap into the line.
Yes, understood. in this case, as you have divined, I am trying to join many cut ends of 10mm together.... can you reccommend a more suitable product for what I am trying to do?
I think you really need to answer the question "Why?" that you have been asked - in particular to indicate to what use the 'joined together' cable will be put and where the cable (and all the joints) will be located.
There are all sorts of ways of joining lengths of cable together - crimping, soldering, terminal blocks, junction boxes etc. - but which, if any, of these methods would be appropriate for you really does depend on what you are wanting to do.
Here's a diagram of how to do it
