Scenario:
1908 large three-storey Midlands town house, re-wired over twenty years ago. I could not know if the supply system would be generically classed as TN-S, TN-C-S, TT or other. There is a short length of approx 2 inch diam steel pipe from the original solid floor under the stairs containing two hefty lead-coated cables (from the street about twenty feet away) supplying a serious-looking black box, details: 100 A, Type IIb, Series 5, 415V, BS1361. Four middle-weight pvc-coated cables appear from the top of this black box to the meter, details: S309.2, AC Watthour meter, 166+ revs/Kw, 1PHZW, Class 2. There is alongside a night-rate meter also. Finally there is the CU, details: Wylex, 8-way, fitted with six re-wirable fuses (it might well take the cartridge type too), 60amp total load warning label, Cat No 804IVY. There are two spare slots, three 5amp lighting circuits, two 30amp ring circuits, and one 30amp cooker slot (not used). We also have some plain candles too...(okay, stop laughing now...I have recently acquired a copy of the OSG!)
I can see the CU is surely now due for an upgrade, complete with MCBs etc, which I shall get a professional to install. The two existing ring circuits are vertically wired, and not horizontally according to floor level, so for starters I am making a new and separate ring for the third floor myself.
Question:
In this context what are my options for a CU, and with which type of protective devices please? It probably ought to have scope for say twelve circuits eg. I need to know because whatever I do now has to be compatible with this new CU. Cable lengths and voltage drop are all relative to the supply and protective device. I need to be sure of the actual limitations. I have a Screwfix, and a BDC catalogue which might illustrate some indicative products available.
I am ignorant about the protective device types as described generically in OSG, Table 7.1 Ring circuits. page 42. 30 - 32amp. (top of table, column one) the three BS refs. and the three cb types, (all shown grouped together in column three).
I intend to install 2.5mm sq pvc cables as in OSG, Sec 7.1.(iii) (a). page 40. And group 2.5mm sq pvc cables as in OSG, Sec 7.2.1 (i). page 41.
Question:
