- Joined
- 27 Jan 2008
- Messages
- 29,045
- Reaction score
- 3,559
- Location
- Country
New toy an energy meter plug in type, plugged in chest freezer in garage detached to test how the new toy works, however some odd readings.
The freezer normally reports using 63 watt however these spikes show varying wattage up to 111 watt and not even, this time of morning I have not opened lid.
Although I can see how some hours the motor will run 4 times and other times 3 times that chart seems to have more variation than expected, yesterday the average watts were 14 today average watts are 11, at 200 kWh/annum the average watts should be 22.8 at 14 watt that's 122.6 kWh/annum which is not far out but at 11 watt it's 96.36 kWh/annum which seems rather low.
So question is the freezer super economic or is the energy meter missing data transmissions? every so often I get this.
does it store info then send again, or if it loses internet or local connection does it mess up the reading, it would seem my info is sent to a server then back to me, so the local hub may still be getting info but not sending it to server so I can read, or it could be the local hub missing chunks of info. Main reason for device is so when I remote switch it, there is a report saying on or off, although I can switch other sockets they don't report their state. So the power measuring was not really why it was bought. Idea is to use it in my house so if I get the green light I know power is still on so I can see if my RCD has tripped, a report as above would mean a visit to check house. Normally it shows like this.
So I know freezer is running and using 66W the Unknown is not that often seen and when it is watch for a minute or so and back to green light. However I expected the chest freezer to show a regular on/off patten except when door has been opened, but the patten is not regular, freezer only 2 months old so should be A1.
I think nothing to worry about and it's the power meter which is out, but other power meter will show what it uses but not how often motor runs and for how long. And it's not the power used but non regular patten which is worrying. What do you think?
