Quick question on Loads, Currents & Cabling
18 Mar 2012
West Midlands
Hi folks,
As an electronics guy, I mostly operate in the 5V and 12V realm but wanted to run the following question on loads and wiring ahead of our test equipment arriving next month:
We'll have 16 x test machines running 24/7 with each consuming max 850W off a standard 13A UK plug/kettle lead (that's 13.6kW or ~60A @ 230V).
Whilst there are many ways of doing this no doubt (and we have 3 phase too), cost is a concern. I like the idea of having dedicated circuits for these sort of things so would the following suffice:
  1. Fit 2 x 32A new breakers/RCBOs to create 2 new Ring Mains each with 4 x double sockets (16 sockets in total)? That would allow us to have 8 machines per ring main. According to my calcs, the above would give a 2A contingency per new circuit (<7% of load) but remember, 850W is the max consumption with the average being closer to 800W and the units themselves as well as the power supplies are all fused.
  2. Should this be done in 2.5mm or 4mm T+E given the max distance from fuse board to last socket on either circuit will be <6m?
  3. Off topic but do sub-meters sync accurately with main meters? If so, are there any cheap-ish recommendations so we can gauge the total units consumed (I assume we'd need 2 if the above setup works)?
The rest of the premises uses very little to no power (a few laptops and 3 tube lights - no other heavy loads). If the above works, it sounds simple (and cheap) for a sparky as everything is ready, open and easily accessible.
They're not interchangeable. Kettles traditionally use C15 plugs, whereas PCs etc are C13.
they are one way, could use the kettle lead to power the PC but not the other way round
Any other thoughts on this apart from using 4mm straight through and not having a ring?
Yes.
This is a place of work, and you are not qualified to design its electrical installation.
You must discuss your requirements and preferences with the electrician who will be doing the work.
Yes.
Was waiting for a 'call an electrician' smarty pants to step in - there's no harm in acquiring knowledge beforehand so I know what the cheapest option is. FYI: I did call one who kept banging on about tapping into a new phase and opening a new line altogether - sounded very $$$ to me.
