D
Doggit
As the song goes, rip it up and start again. You need to get the floor out, and install new joists, then fit the floor, reinforce the dormer/perlin (may well need a flitch plate either side of the dormer), put in the insulation and then plasterboard and plaster the rooms. You don't need to worry about a membrane under the tiles, and a 30mm air gap under the insulation should be fine so you'll want a 50mm batten on top of the joists, and 100mm of celotex in between the joists, then 30mm plus plasterboard across the joists to stop theremal bridging.
Any response from the estate agents. If we assume that you did the letter last week, you may not get a reply for a couple more days, but if you don't, then send a copy to the senior partner, as the firm may well be liable, and they'd need to know. Do you have legal protection on your hous insurance.
