- Joined
- 26 Aug 2016
- Messages
- 6,830
- Reaction score
- 1,009
- Country
Neutrals don't really have an MCB as the MCB is single pole, they are just all connected into the neutral bar (for that RCD) together.I can't see how it can be on a different circuit/RCD if, as we have been told (twice), the proposed source of the neutral shares the same MCB.
As an interesting thought, if your install is wired in singles and you loop neutrals through the switch, and you have a 2 gang switch for upstairs and downstairs on different circuits, you would wire one neutral to each switch in parallel, but as the neutral goes to the first switch, which "circuit" is it on?
Electrically there's no difference until it goes off to the light.
