Has anyone run into an issue where the standard 150mm R9 foiled white soffit board is not large enough to cover a large arch.
I probably need 165mm to fill the arch completely.....I know this is a special foil used on R9 systems so the likelihood of another manufacturers white wood grain effect foil matching in is quite unlikely, has anyone else had this problem and did you find a good match with another manufacturer?
