Changing back to a house
18 Feb 2006
Birmingham
Hi all,
Going to go and see a Victorian house on Saturday which was converted into 5 flats back in 1988. If I was to buy, I would want to return it to a single dwelling.
My question; is this Something councils (Birmingham) are in favour of, considering the loss of revenue from £5500pa to £2400pa. I would of course not want it if I had to pay £5500 for council tax.
Also I'm guessing it has separate gas and electric meters, consumer units. How hard & expensive are these to merge?
Anyone also have experience of getting a residential mortgage on a property with flats that will be converted back into single house
Thanks in advance
The law in this regard is a mess. Presently, the only way to know whether the local authority considers the loss of residential units to be material is to ask them. A lawful development certificate would (I think) confirm the issue.
Thanks for that. I actually dropped the council an email last night, so will see what they say.
Any ideas about meters?
I think you need to find out what the actual situation is currently in that regard too.
Hi all,
Thanks in advance
In planning terms, generally, it should be okay. The planning system isn't really interested in loss of revenue. 5 Flats -> 1 dwelling should be fine; you've got less demand on the area, less trips, less parking needed, still a residential use etc etc.
Hi all,
Thanks in advance
That’s good to know Luke.
Think my main issue with be financing if I do like it. Not sure how lenders offering a residential mortgage will feel about a house split in 5
Just looked at the epc's for each flat and looks like hot water and heating is all on electric. Maybe gas wasn't split, will report back tomorrow
Right went yesterday but only had access to 1 of the 5 flats due to them currently being let and awaiting access. All electric was split in the inner porch, with 5 electric meters. Most likely would need full rewire & plumbing.
With regards to conversion, my understanding of it is that it is entirely dependant on the local plan for the area. To give an example, it might be fine in Margate say, where there was an oversupply of conversions, but in some other area it might not be fine atall as it would reduce the stock of housing. It all depends on the circumstances and context of the area. Have you checked the planning history and read the local plan???
As far as lending goes if there are tenants in place would you be getting vacant possession or buying a building with tenants in? Also if you gut all the bathrooms and kitchens it might not be mortgageable until an amount of renovation work was done. My guess is you might be looking at stage payments.
