Ok here goes…..I moved into a house in January which has got a lovely new bathroom and nice thermostatic shower. The setup is a traditional vented system with a header tank in the loft and hot water cylinder in a cupboard in a bedroom. There is a pump in this cupboard that powers the shower to provide adequate pressure. The problem I have is that the pump is a cheap salamander one and makes a noise that measures 70dbs. This was installed in December (before we moved in) by a plumber who charged the previous occupiers £550. My understanding was that there was some problem with a pump in the loft. I contacted Salamander (I know pumps can be noisy but this is ridiculous) who said that it wasn’t installed correctly (too sharp bends, pipes going to and from different diameters). The plumber then stopped responding to me about this despite his work being covered for a year. Although frustrating, I don’t think it is worth me pursuing any further with either the plumber or Salamander.
The noise was fine when it was my wife and me, but we now have a baby that sleeps in this room and it is difficult to shower when it makes such a loud noise. There is now what seems to be airlock problems where it sometimes decides not to switch on which is rectified by turning on the handheld part of shower whilst it rests on the floor.
The installation of an unvented cylinder seems to be the most appropriate solution in my eyes for the below reasons
- It will allow showers that don’t wake up the entire house
- Allow decent pressure in the en-suite when I put in a new shower next year (this is a factor as the existing pump wouldn’t do this and no one seems to have a good word to about shower pumps)
- Freed up cupboard in bedroom would be very useful
- Faster bath fill times
- Is the pressurised a good idea? Presumably he thinks it is as he said my boiler won’t need to work as hard. When I put this to the other plumber, he said he wouldn’t recommend it as we don’t know the integrity of the pipes and there would be a greater chance of leaks.
- I’m a bit limited by loft space as I have a low apex. Is 210 litres enough? There will be two bathrooms and eventually 2-3 children.
- Any better ideas than having this solution fitted?
- The £1400 plumber measured my flow rate and the £2300 one did not but did run a tap upstairs. The flow rate was 15l per minute. He says that this is sufficient. I see a lot of stuff out there saying a minimum of 20l. Should I be concerned by this? I don't want poor showers after spending this money!
