What John just said. I cut back / down a load of laurels last winter. each time the loose pile of branches was massive, maybe 4' by 6' and 5' tall if it was in one place (the garden is on the side of a valley so it was in two or three smaller piles).
I shredded that with a Bosch AXT 25TD (slightly less capable than the AXT 25TC mentioned earlier) and each time I ended up with:
- loads & loads of shreddings
- a few branches / trunks clearly thicker than anything in your pictures (e.g. 3-6") which I did not put anywhere near the shredder
- a pile of branches that would probably fit in one ot two of those large green garden sacks (the sort that are c. 2' across and almost 4' tall)
I put plenty of this last group into the shredder thin end first and let it chew off what it could, which is often more than you might expect.
Look at the pictures of the AXT 25TC here
https://www.amazon.co.uk/Bosch-Quiet-Shredder-Cutting-Capacity/dp/B00D43EF06
and you will see that the top comes off and stores in the bin at the bottom to save space in storage. That also makes it easy to clear if it gets jammed.
