Assuming a 32 A MCB in the CU, standard ring.To be absolutely clear you are wrong. The fuse is to protect the cable not the appliance which should be internally protected. Appliances are sold all over the world and most of it does not have fused plugs and rely on the MCB or fuse in the CU which in Europe is usually 16 amp.
So if a lowish power (e.g. small fridge) appliance flex was wired directly into an FCU, which is electrically no different to using a cable + flex outlet, what rating fuse should go in the FCU?
And if separate flex outlet was used, what size fuse?
I'll gratefully accept corrections.
