Festive/Christmas Lighting
20 Feb 2017
Melbourne, Australia
Australia
I would appreciate advice as to whether any temporary Festive/Christmas lighting for outdoor, indoor, Christmas Tree use - etc. is allowed to be powered directly from the "Mains" supply in the UK or is it required that all such temporary lighting be powered by Extra Low Voltage transformers, controllers, double insulated power supplies etc.
(Only Extra Low Voltage supplied devices of this type are allowed for these purposes in this country and, as far as I can remember, this has been the case since at least the 1950s.)
Apparently, 120 V Mains supply "Festive" lighting of this type is still allowed in North America ! ! !
Based on the question the OP asked
This would seem to be an appropriate forum
Short answer - in the UK we can plug anything in to the mains outlets providing the manufacturer has designed it for the environment it's used in.
At this time of the year, I'm sure there will be the usual selection of multi-way adapters wrapped in bin liners with a mains flex jammed through a window frame!
Yes, but your country has some strange ideas about electricity, including the one that job protection for electricians should be bought at the cost of people's lives.
That's interesting. You mean that if I walk down an Australian street, and see lamp festoons across a shopfront, round a beergarden, or running from one side of the street to another, over the shoppers heads, they're all ELV?
https://assets.atdw-online.com.au/i...24d24fe.jpeg?rect=172,0,3451,2588&w=800&h=600
https://assets.atdw-online.com.au/i...2073ff1fb.jpeg?rect=0,0,2133,1600&w=800&h=600
https://www.timeout.com/melbourne/things-to-do/christmas-in-melbourne
https://www.timeout.com/melbourne/shopping/summer-night-markets-in-melbourne?package_page=97582
If so, the sort of things you illustrate must involves some fairly seriously fat cables - and goodness knows how fat in the days (if they have moved on from them!) of incandescent bulbs/lamps!
I'm only guessing here, but I could easily imagine a situation in which commercial or municipal exterior lights installed by professionals may be subject to different rules from those sold in DIY stores for domestic use.
In the UK, these
https://www.tlc-direct.co.uk/Main_Index/Xmas_Lights/Festoon_Party_Lights/index.html
are sold with an ordinary fused plug.
For a permanent/fixed installation, it seems there is a regulation of the equipment to be used, seemingly UK/EU harmonised. I think my local street market has supply pillars for something like this.
https://www.tlc-direct.co.uk/Main_Index/Xmas_Lights/Festoon_Harness/index.html
In the UK, there is no licence required to purchase electrical equipment or components.
IIRC there are regulations in Australia intended to protect the income of certain trades.
That's not a 'regulation' - it's a Standard.
Some certainly seem to believe that to be intention, although I don't doubt that the regulations were probably created in the name of 'safety'. Why Australia should require a greater degree of electrical 'safety' than almost any other country, I couldn't tell you.
Unless something has changed which I haven't noticed, ~230V mains "festive" lighting is still allowed in the UK.
Does the insistence on ELV lighting in Australia to which you refer apply only to 'temporary' lighting - and, if so, can one get around it by making one's festive lighting 'permanent'?
It's not working: https://www.voltimum.com.au/search/site/electrocution deaths in australia
It's not got it.
Why they thought that the Australian regime would work differently to the NZ one I couldn't tell you.
Indeed - domestic electrocutions per capita appear to be more than double those in the UK - despite (or perhaps because of?) their level of regulation of electrical work.
What are you basing this on, as I don't believe any official uk stats exist, or have the government starting recording them again?
I'm not sure from where they were ultimately derived, but the most recent published UK stats I've seen indicated about 22 domestic electrocutions in a year, in a population which is, what, abut 64 million? In contrast, although it's all a bit muddled, I think the link BAS posted suggests 15 domestic electrocutions per year in a population which I think is around 25 million.
Of course, in both of the countries, at least some of the electrocutions will inevitably be ones which are in no way the fault of the electrical installations concerned (and, incidentally, a good few are probably ones which an RCD could not have prevented)
Crude data on the number of UK deaths due to electric shock are available in the UK from death certification records, but those records do not allow one to distinguish between domestic and other situations.
