Hi
Does anyone have any experience of the Pro Ring door bell versus the Elite version that they can share? I understand that the only difference with Elite is that it is PoE which means that if your router goes down the bell will not work?
I am towards the end stage of a building project and trying to workout the setup for a Ring Pro doorbell (hardwired version). I will be having three chimers/sounders around the house. My setup will be as follows:
First chimer located within a cupboard near the front door where the main fuse board and bell transformer will be. Chimer and transformer will be approx 10m cable run from the Ring doorbell
Second chimer will be located on the ground floor towards the back of the house. I would say approx 20-25m cable run from the Ring Pro door bell
Third chimer will be on the first floor, approx 15-20m cable run from the Ring Pro door bell
Questions:
1. What type of transformer can I purchase that can power all three chimers (any recommendation/provide a few options including Friedland or some good quality makes
2. What type of cable should I be using given the long cable runs?
3. How should I get the builder to run the setup. Is it one cable from the Ring Pro door bell to the transformer and then one cable from the transformer to each of the sounders or some other way?
Questions:
