texecom premier elite power terminals
PA zones and fire zones work 24/7 and don't have to be set.
however for intrusion, your alarm needs to be set.
if you walk to your keypad and start the arming process, the PIR's will pick you up as you walk to the door?
On the Premier elite panels the arming mode is entry/exit, which means it sees the e/e device go active then secure and the system sets, with a PIR set to e/e its likely it will see lots of activity and give you grief, however if you set the arming mode to timed exit, it doesn't look for a device at all, it just gives you x amount of time to get out of the building.
The e/e PIR will start the entry timer when you re-enter the house.
Got it and yes I am getting that grief already. I will change this. Thanks
lol I was referring to sparkymarka and his comments both ancient past and now.
looks like you will have a few things to learn and trial and error can be a great teacher
Could be worst on the electrial section you never get a straight answer just things going off on a tangent ! Lol
