Hi all
I have read the page
https://www.diynot.com/pages/el/el032.php as I wanted to add a separately controlled ceiling light in the bathroom.
Firist I changed the switch (well a lightwave dimmer) to a 2 gang. fed a new 1.5mm twin and earth to the ceiling.
Then I located the existing junction boxes that are used for the wall lights.
There was one junction box with the switchwire going in and another twin and earth coming in from another room.
They are joined red to brown(new grey twin and earth) black to blue and earth.
when the switch is off I get 230v between red and black and 230v between red and earth
when the switch is on I get 56v between red and black and 230v between red and earth
the next junction box has a twin and earth going to the lamps and a another disappearing to another room.
Light switched off and 0 v between live and neutral and also between live and earth
switch the light on and the voltage goes to 170v !!
This was all discovered after following the instruction on the linked page.
I split the feed to get my "loop through" feed, put that into some choc bloc to test the light (replicating a ceiling rose) fed in my switch feed and connected my lamp.
the lamp worked but was very dim and low and behold the feed to the lamp was 70v
Any ideas what on earth is going on??
many thanks
many thanks
