Pressure vessels and leaking overflow
2 Feb 2018
Hi all
I have the above vessels connected to my CH/HW system. The overflows leak outside the house primarily when the HW is active and I’ve checked the pressure of each vessel with the system off. The red vessel (CH I think) shows 1 bar and the white shows nothing at all.....
Hot water tank spec on the side suggests 3 bar for the connected pressure vessel so should I just pump the white one back up?
Thanks in advance!
Paul
Both need to pressure to be released for it's relative system before checking the EV's pre-charge. The white vessel will be for an un-vented hot water cylinder. You need a qualified engineer in to ensure it is suitably setup to safeguard your un-vented cylinder .... the pressure needs to be taken out the system before the vessel is pre-charged ...... aaaaaand it needs to be pre-charged to match the system design pressure as set at the inlet.
"should I just pump the white one back up?
Not quite, you need to turn off the cold water supply to it first and turn on a hot tap and leave it open. Then when the pressure is relieved you can pump it up. Then finally close the tap and turn on the cold water again.
Otherwise the pressure will go up quickly but you won't have actually put any air in.
170 lites more like :whistle:
Even worse!
How do you get that, I make it 18l, to add 3bar above ambient that would be 4bar absolute, will have 18l in already so add another 3x18l into it.
Of course the work done will be exponential as you'd have to work against 3bar pressure for the last stroke.
Glad I don't have that to charge by hand, lay off the gym for a day and do that instead
Says on the side 3 bar which would be relative to atmospheric at 1 bar. Th
Don’t feel it necessary replying to threads especially when not qualified to do so.
I wrote it in the nicest possible way so as not to offend you.;)
best way to learn by people pointing your errors out! Look up growth mindset on line
Thing is, you are giving advise. Not learning. If we weren't here to correct you, where would the op be?
Exactly, that's why you're so valuable to the forum Dan!
To be fair I could make it clearer I'm not a pro, but wiring it on every post looks stupid.
So far you've taught me a lot, I certainly owe you a pint:love:
Maybe you can enlighten me on the whole 3 bar charge pressure?
