In our utility room there is a sink, central heating boiler, washing machine and tumble dryer. The room is about 7.5 cubic metres and has no opening window so to meet building regs needed an extractor fan. When we had the kitchen redone end of last year the sparky fitted a quite expensive (£100 ish) fan activated by pull cord with humidistat. It isn't wired to come on with the light. After only a few weeks it's packed up already and as there's no receipt I need to buy another. It's 6 inches square with a 4 inch diameter outlet across an exterior wall.
Bit of background - I've never had much luck with extractor fans, in a previous house I must have replaced the bathroom fan about once a year, and tried timers and humidistats to control length of staying on, they all seemed equally unreliable.
I normally run the dryer overnight. So ideally I'd like a fan that comes on with a pull cord (ie independent of whether the light is on, to save having the light on all the time the fan is running) and a timer that keeps it running for around 3 hours which is the typical length of a drying cycle. However not many fans seem to give the duration the timer keeps the fan on for after pulling the cord, and those that do only stay on for about 20mins which is way too short for the purpose I need it for. I could just get a fan that stays on until I turn it off but then it would be running for hours when it didn't need to and might wear out sooner. Given my appalling track record with extractor fans that will happen sooner or later.
So please can someone recommend me a fan suitable for running at 3 hours at a time for when the dryer is on and that does enough air changes (I think for a utility room it's 10 per hour so 75cubic m/hr, right)? Not wanting to spend a fortune either.
Also can I fit it myself (I could probably follow a + and - wiring diagram!) or is a registered sparky required to fit a replacement fan? Undoubtedly it won't be the last one I get through.
The really dumb thing is that the tumble dryer is a heat pump model so the room doesn't steam up even with the door shut and dryer running - I'm only doing this to satisfy the very fussy building regs inspector who is visiting shortly to sign off the kitchen.
