Non-standard power strips sought
Status
Not open for further replies.
Before a moderator edited it for you it looked like this:
i.e. you made it look as if StephenOak had written all of that text - you made it look as if it was all "StephenOak said".
Now it looks like this:
Can you see the difference?
Yes, I see the difference. I don't know how it came to be incorrect. Perhaps I failed to put a space after the quoted material, as I have done now. I hope this turns out all right. As far as this incompetent person can see, what you do is: highlight the part that you want to quote, then go to the answer panel (where it has been copied to), leave a space, then type in a reply. Other than that, I wouldn't know what else to do. Anyway, thanks for pointing out my error. I wouldn't want to cause confusion for anyone.
A.W.
Not sure what you mean - highlighting text doesn't put it in the reply panel - clicking the Quote button does that
and in this case gets you this (with O changed to 0 to stop it being interpreted as a quote):
[QU0TE="alwaysworried, post: 4095736, member: 185370"]Yes, I see the difference. I don't know how it came to be incorrect. Perhaps I failed to put a space after the quoted material, as I have done now. I hope this turns out all right. As far as this incompetent person can see, what you do is: highlight the part that you want to quote, then go to the answer panel (where it has been copied to), leave a space, then type in a reply. Other than that, I wouldn't know what else to do. Anyway, thanks for pointing out my error. I wouldn't want to cause confusion for anyone.
A.W.[/QU0TE]​
which looks like
A.W.
Matching up [QU0TE] [/QU0TE] around what you actually want to quote is what you need to do, if it's not the whole post, so
[QU0TE="alwaysworried, post: 4095736, member: 185370"]Yes, I see the difference. I don't know how it came to be incorrect. Perhaps I failed to put a space after the quoted material, as I have done now. I hope this turns out all right. [/QU0TE]
[QU0TE]As far as this incompetent person can see, what you do is: highlight the part that you want to quote, then go to the answer panel (where it has been copied to), leave a space, then type in a reply. Other than that, I wouldn't know what else to do. Anyway, thanks for pointing out my error. I wouldn't want to cause confusion for anyone.
A.W.[/QU0TE]​
gets you
A.W.
It can be a PITA to put it right if you get it wrong, as the site will insert [/QU0TE]s where it thinks you've missed them.
As I said, before it got removed, we all mess it up at times, but I was surprised that you thought it looked OK first time round, that's all.
Status
