Not much lagging on those pipes even indoors, I assume that's been corrected since?
Better than nothing, that's classed as "economy" grade because it doesn't meet any regsYes all done, think it's 13mm.
I suspect that there are a few bodge jobs in the house my son bought. However they see a bit stuck for choice in the price range and location and, in time, it’ll be a very nice home. They had someone out and he wouldn’t climb a ladder either (restricted space and too windy) so they’ve cut the pipe inside pending a longer term fix when weather improves.
Have you considered an Ice valve? I believe you can get these in hardware stores and you seem to have room to install one inside.
Is there a plastic soil (vent) pipe passing anywhere through your loft space Buxus?
I think this really shows the difference between the jobs where someone has chucked a boiler on the wall, (possibly the cheapest quote), and someone who has put a bit of thought into the job, and designed a system where the condensate is either run internally, or is protected as much as possible against freezing.
I know this will be of little joy to anyone sitting in a cold house, but hopefully it'll get the message across that the condensate drain is also a vital part of the installation and its worth asking the installer what the plan is for it when looking at a new boiler, or looking at a property with an existing boiler installed.
Shoving boilers in lofts to save space is fine, until this happens, then the whole installation is then at risk as the frost stat is irrelevant, due to boiler not being able to function as condensate drain is frozen...
There is a soil stack within 4m but it terminates below loft height, could I route the condensate internally in the loft, exit then angle into the soil pipe below the AAV?
