texecom panel not responding
9 Mar 2018
for some reason my panel is not loading, shows v10.100 Add=001 w-7,7_s been like this for hours
9
Loading from what ? Is it a new install ? Or been fitted a few years ? Did it do,it after a power cut ? A bit more information is needed
new out of the box, power up few times fine, has had a comIP fitted and has been working with that connected only has one PIR and bell attached, but now is not loading, even with comIP not connected
I take it it's a live panel ? Have you plugged the front keypad onto the com port instead of the keypad port ?
front keypad is plug into the "engineer REW" port, which i think is correct, its not in the com port.
its not a LIVE system, i have it for testing integration with control4.
Have you tried pressing a key ,or power down and repower ,what else is connect to the panel ?
yup tried pushing buttons, also tried loading defaults, have removed the comIP only thing added, can you do a factory reset somehow??? have logged a ticket with texe.com as well now.
well when the keypad displays the version of the keypad and address, it suggest that it has power but there is an issue with T and R connections, is the correct cable on correctly.
show a picture of where its plugged in, its clear from the picture there doesn't appear to be a fault with the front cover, so suspect cable/ connection.
this was a cable issue, replaced and now fine, thanks.
