I am having a 4kW solar PV system professionally fitted. I have a degree in electrical engineering which is sometimes a curse. Whilst I don't have much knowledge of household electrical practices and regulations, I have enough theory to question what the installers are doing.
I asked today how the feed from the inverter is patched into the house system, and they told me it will use a spare fuseway in the distribution board. It was only after he'd left that the following hit me:
- Does he mean by this that the live wire from the inverter would go into the 'top' of an MCB, thus going through the MCB in reverse to the live bus? Surely you can't draw current the wrong way through an MCB? They are not bidirectional like wire fuses.
- This would also bypass the RCD protection for the bus because the incoming feed would be connected to the protected (output) side of the RCD. If so this seems dangerous to me if not illegal.
- My consumer unit has a split bus. It is wired so the downstairs ring shares a bus with the upstairs lighting, and vice versa. This is so a trip caused by (eg) a faulty hairdryer won't extinguish the lights in the same room where the fault happened. But, similarly to my question about the MCB, whichever bus you connected the inverter to, current would have to flow backwards through the RCD on that bus (and then forwards through the RCD on the opposite bus) in order to deliver power to both.
