D
durhamplumber
Rofl......Utter Tosh.Gas pipes are often coated internally with an oily substance
Why?Rofl......Utter Tosh.
Everyday is a schoolday..ThankyouIt's a regional thing I think, according to where the gas originated from, but it does occur. That's why Siemens recently had to change the diaphragm material in their gas valves - said oily substance was making them stick, causing boiler breakdowns
That is in the gas rather than on the inside of pipes put there by the pipe makers. A good flush through will rid of any oily stuff in the pipe. Yes you are right, gas valve makers did have problems with differing types of gas.It's a regional thing I think, according to where the gas originated from, but it does occur. That's why Siemens recently had to change the diaphragm material in their gas valves - said oily substance was making them stick, causing boiler breakdowns
It passes between joists, through floor void, through a wall and into a concrete flooring under my stairs where it turns vertically.But your post suggests that you’re only going through a 200-300mm slab and then connecting onto that stub of pipe both ends to pipe up the water!
So, on that basis... drilling a 25mm hole, to take 22mm pipe through a slab of concrete is no sweat!?
Oh, jesus.Just be careful you don’t end up with what’s known as a Jewish shower.
Didn't he bath in water/wine ? Anyway I have to hold my hands up about the smell comment - didn't read the OP properly and was referring to steel pipe ( that I used as a temporary connection to a tap once ) that pongedOh, jesus.![]()
