- Joined
- 22 Jul 2016
- Messages
- 6,393
- Reaction score
- 1,234
- Country
i have a portable a/c unit that uses a tumble drier type hose to exhaust it's warm exhaust.
It was previously used in my gf's flat, upstairs, with sash windows. So I made a panel with hole and used the sash to trap it.
I now want to use it in my house. I cannot really core drill through the front wall but originally the house had a porch built so that the front door was recessed from the building line by about two feet- and four feet wide or so
Later, a single glazed multi-panneled glass and wood porch door was added to the building line
So I have a piece of wall in the porch that was an external wall and is now leading into a porch which has two small French doors, and a similar 12" wide panel on each side
My idea is to drill into the sidewall/ return and exhaust into the porch area, then duct this a couple of feet to the front and through a wooden panel replacing one of the glass bottom panels.I would box the duct in and apply insulation inside the box
My concerns are making the house cold in the winter
I could make the pipe removable so that the whole box was filled with insulation and plug the internal hole with a foam plug.
Comments?
Comments?
