Electrics and phone in a WC
27 Jun 2009
Nottinghamshire
I have a downstairs WC that had an electric shower and hand basin in it. The shower is being removed. What are the regulations to have a BT phone socket and power in there to power the router etc?
tecnicaly its your wiring as its after the bt master socket
a hand basin will effect a 230v sockets position but if its in a secure location needing a tool to open a router with a say 12v supply cable will work far closer to the sink
... a hand basin will effect a 230v sockets position but if its in a secure location needing a tool to open a router with a say 12v supply cable will work far closer to the sink
As you presumably know, there are no explicit regulations relating to the proximity of 230V sockets to sinks - but common sense needs to prevail (and to satisfy the 'blanket' regulations, which again relate primarily to common sense).
Were the shower not being removed, things could, of course, be very different.
The regulation applies to bathrooms, and is measured from a fixed shower or bath, not basins.
In all other rooms, the installation must be suitable for its position, so sensibly not where it will be splashed or dripped on. I can't explain why so many people like to put a socket under the kitchen sink, but it is not expressly forbidden.
You could mount it high up, out of drip and splash range.
yes john thanks i realize a sink in a kitchen is no different to sink elsewhere
i am sort off assuming it may still have a loo or more off a bathroom feel rather than a study with a sink hence my suggestions :D
It's a "downstairs WC", so I presume it is retaining a loo! We've been told that the shower is to be removed, and I presume that the OP would have mentioned if there were a bath!
However, a loo is not relevant - the only thing which invokes any explicit regulations about electrical items is the presence of a bath or shower - loos, bidets and basins/sinks don't count. ... as I and JohnD have both said, in such cases it just really a matter of common sense.
Perfect, that makes sense guys. Yes, shower to be removed and then it’ll just be a nice square room with a toilet and sink next to each other and then a unit with a socket, router and phone the opposite corner. A long way from any splashes or hazards.
Regarding the the bt line. It comes out of the floor one side of the wall and would basically need moving from one side of the wall to the wall behind. I’d even be happy with leaving the master socket where it is and then having an alternative provision on the wall behind it if that makes it easier?
I just hate phone extension after phone extension like the used to do. Looks terrible now you can have cordless phones and put additional hand sets in other rooms easily. I know in a power cut they stop working though and that’s the downside.
To get the bt socket on the wall behind it, is it easiest to leave the socket in situe and run another point off it behind it?
Yes, but where I live, you can buy flex more than 500mm long.
BT used to have thousands of combination phone and WC installations all over the UK.
So, how would you suggest getting a BT socket on the reverse of this wall?
Yes that’s right but they work fine for what I’ve got them in for tbh. I don’t rrakly want a full rewire to run CAT6 to everywhere do I tbh? A lot of disruption in order to do that. I agree that having network cable in would be great but the home plugs do the trick.
