- Joined
- 19 May 2018
- Messages
- 16
- Reaction score
- 0
- Country
Hello Forum- first post so please go easy! Hoping for some advice....
As part of our extension - the building control officer has noted that the pre-existing loft room (in a separate area to the area we are building) has not had a previous building regs approval (it was probably done c. 25 year ago by the look of the glazing and woodwork around it.)
This existing loft will have a doorway into the 'new' area, and whilst we will be replacing the internal external insulation , we were otherwise leaving it relatively untouched.
The BCO has said in order to sign off on the extension, the insulation will require upgrading in the old loft room and the floor (which would involve up-speccing the floor joists)
- he is saying that he'll not sign off the completion certificate until the insulation is fully upgraded in the old loft (both the room, and the remaining unfilled loft) - which would obviously trigger the need for a shed load of work on the ‘existing’ loft, which we’d not intended to touch...
We will not be using this previously fitted out loft room as anything other than storage - as we have a couple of new, full hieight rooms in the ‘new’ bit...
He's also said in our meeting yesterday that 'the worst the can happen is nothing' - i.e. there are no longer local authority enforcements...
I begged to differ, as my understanding that unless the completion certificate is issued - there are elements of the buildings insurance that are not covered...
He’s not been hugely helpful in giving advice, just refers to the L1b regs
Just to further complicate matters - we’ve had the existing roof re-tiled to match the new area - will add some pics to add context - but any advice most welcome - my preference would be to ‘leave it as is’ - but I understand that reverting it to ‘storage’ from ‘illegal loft room’ may involve removing heating, plug sockets & restricing access from the main house (I.e it can’t have a ‘normal’ door - otherwise it’s trying to be a habitable room....
Or should I just not worry about the sign off of it? (Given it was non-compliant before)
Sorry for the rambling post - but this (in conjunction with the other bumps in the road on out project) has been doing my head in!
Timmer
Timmer
