Hi. I am replacing my kitchen roof shortly. It is a cold deck flat roof (built years ago) with not ventilation and has basically rotted from the underside over the years, now leaks and is generally just a piece of rubbish.
I will be replacing it with a cold desk style again (warm roof would raise the height too much) and will have the proper ventilation, EPDM covering and such.
With the scene set, my question is about the lighting wiring. I will be using Celotex type insulation boards inside the roof, leaving the gap between that and the outer roof for the ventilation but, what should I do about the wiring? Can the lighting wiring run underneath the insulation, ie, the Celetex boards sit on top fo the wiring or do I need to do something else?
