Upvc door handle needs swearing at to lock
30 Nov 2010
Lancashire
Hi everyone. Upvc patio doors in my house are a pain to lock. I have to not only hold the handle up but really push it up hard to enable me turn the key to lock it. Question is what's worn, damaged or out of adjustment. I should surely just be able to shut the door, lift the handle to engage the mechanism, release the handle then turn the mey to lock. Any help welcome
Patio doors are sliding doors. Are you talking about patio doors or French doors?
In theory it should just be a bit of adjusting.
Are they under guarentee?
If not post some photos. Inside and out. Overall door inc the hinges
If a suitable lubricant doesn’t work the multipoint handle might need replacing. Either way this video will give you an idea what is involved if only so you are better informed when asking a tradesman to do it.
Blup
P.S have assumed you mean they are French doors
Blup
Fell at the first hurdle they're french doors. Pics attached
I expect the strike / hooks arent engaging in the strike plate, it stops the mechanism moving up enough for the euro cylinder lug to turn.
Easy to confirm - does the door handle raise and lock easily if done with door open.
As above if they operate and lock easily when in the open position then the doors have probably dropped and just need adjusting or "toe & healing"
They look pretty new, Will the fitters not come back and adjust them under guarantee? Best to give them a shout first.
Its a 10min job for someone who knows what they are doing
I suspected that as the bottom of the door wasnt fitting up and engaging the latch to pull it in. Ive adjusted that but no difference. If i open the door and try to lock its exactly the same. Cheers for response so far. Im a curious guy so like to tackle this myself if possible
Next thing to do is take off the handle and lock and see if the lock works ok on the ground
is it the slave or master door causing the problem? it looks like both have a lock and handle
I would think its the slave? The master works fine. The fault lies with the door you can open without having to unlock or open the other so take it thats the slave
That would be the master door, The main door that is used most often.
